Fallen shift lever!!!
mx3gtracer
Post by mx3gtracer »
my shift lever keeps falling and I'm starting to get tired of restling it up into the shifter bushing at stop lights, what do I need to get or do to get this shift lever to keep from falling down and resting on the exhaust? is it a spring, pin, or something else? and is it something fairly easy to do or should I end up taking it to a dealer?
Custommx3
Site Administrator
Post by Custommx3 »
replace the shifter assembly or search for shifter anti-drop bracket
Boris
Post by Boris »
I just bought the whole assembly from mazda. After tax it was like $100.52
1993 1.6L SOHC. Mazdaspeed mounts, BP09 ECU, BP VAF, Fidanza miata flywheel, exedy miata pressure plate, centerforce mx3 disc, tokico struts, B&G lowering springs, and some sh***y motomaster tires.
neutral
Post by neutral »
Looks like Chris still has some shift brackets to sell. Mine works great and price was right. Check out this thread...
http://www.mx-3.com/phpbb2/viewtopic.ph ... c&&start=0
Image -Jim
