distributor change cost
- mitmaks
how much would you pay to have disty changed on k8?
free... well to have it changed it takes like 3 - 5 minutes. Take cap and rotor off (note the position) take 2 bolts off.. pull... get new disty and insert in same position. Install new rotor (make sure its same size either big or small for new disty) Install cap and walla.. you dont even need to take off the cables.. unless u nget a new cap. Honestly you are giving your money away if you are paying someone to do it..
-hec
