new owner-need help with rotor removal
sharpmx3
Post by sharpmx3 »
I am the new owner of a neglegted 1993 MX3 and while replacing the front brake pads I wanted to go ahead and replace the bearing because there is some play side to side. I took the front of the brake caliper off and then removed the axel nut but the rotor will not come off. Am I missing something?? Any help would be appreciated.
93 MX-3, 4cyl, auto
PATDIESEL
Post by PATDIESEL »
They rust on pretty well. A rubber mallet and a good swing will usualy get it off. If not then a hammer hitting a block of wood resting on the rotor should get it. WD-40 or some other penetrating oil if it is a real pain, but only as a last resort. The oil can cause loss of brakes if it gets onto the brake parts.
Mx3er
Post by Mx3er »
the rotor will come off with a good hit to the face of the rotor, by the face i mean the space between the studs.
but anyways you cant change the front wheel bearing at home unless you have a press. its a press in wheel bearing, most machine shops can do this for 20-50 bucks
GM tech, Mazda tunner
sharpmx3
Post by sharpmx3 »
Thank you for responding, I will give those suggestions a try. I just didn't want to tear something up by overlooking something simple.
93 MX-3, 4cyl, auto
lakersfan1
Post by lakersfan1 »
PATDIESEL wrote: The oil can cause loss of brakes if it gets onto the brake parts.
That's what brake cleaner is for.
jrors
Post by jrors »
Use PB Blaster, if you haven't gotten it off yet. I had the same problem last year. I bought a can from Autozone and it came off easily after 10 minutes.
If you fall, then get back up........Luck favors the prepared
2fazed
Post by 2fazed »
On the rotor, there should be a bolt hole. Find a bolt that fits, which I'm pretty sure is one of your caliper bolts, and screw it in. It will push the rotor out.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
sharpmx3
Post by sharpmx3 »
Thanks to all for the help, I got it off and also had to replace the ball joint. Car is now 'on the road' and doing good.
93 MX-3, 4cyl, auto
