Lets make the longest thread EVER!!!!!
http://www.seabreezecomputers.com/superhero/
which superhero are you?
http://www.sherdog.net/forums/showthrea ... 636&page=3
saddest picture ive ever seen!!
- JWMX3
Im the FlashDavidOS wrote:http://www.seabreezecomputers.com/superhero/
Im the Green LanternDavidOS wrote:http://www.seabreezecomputers.com/superhero/
1992 WHITE 1.6l SOHC saving for a BPT swap next year, New interior next month, and new Paint Hooray
Your results:
You are Spider-Man
You are intelligent, witty, a bit geeky and have great power and responsibility.
Spider-Man -------------------------- 85%
Hulk-------------------------- 75%
Superman-------------------------- 60%
94 Mx-3 Precidia
- JWMX3
ride the ponie
If i do a cam grind on my SOHC geo metro, will it be about 320 horsepower ? anyone know ? i need an answer before i break out the dremel
- happyclown
I met a girl at work and we both stay overtime and pass notes around.
tech calls are so cool..
im saying this because... yes thats why
CMON KEEP IT GOING
CMON KEEP IT GOING
-hec
- happyclown
- happyclown
