I purchased a set of 94-96 GS alloy wheels and was hoping to get some info on them? What diameter is the hub opening for these wheels, is it 54.1mm like the protege and miata?
Thanks
Need 94-96 GS wheel information
silentbob343
silentbob343
If anybody has these wheels could you possibly take a picture of the backside or at least tell me if this is normal?
Here are what mine look like.
I know the area I'm trying to point out is difficult to see and I can try to get a better picture if that will help.
Tried these with DX, LX, and GTX knuckles. One theory was hubcentric rings that have corroded onto the wheel, but if the MX-3 has a different hub diameter that would be the most likely culprit.
silentbob343
