Protege transmission question.
MechaManZero
Post by MechaManZero »
I am trying to find an easier fix for the whole electrical to mechanical speedo situation. I was thinking changing the manual speedo in the tranny to an electrical. The Ford Escort GT seems to have one in the early 90s. Does anyone know if it would work.
Çlark
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
atlantamx3
Post by atlantamx3 »
Just get a speedo gear, cable & cluster from a SOHC. It will all plug & play with no problems.
:D
~Perry
Please visit
http://www.mx3-atlanta.com
MechaManZero
if only someone had one that is willing to sell a whole assembly to me :( . I can't even afford it I get my paycheck every two weeks and got mine on friday, all spent on bills and parts. And next paycheck I need to buy that GTR ECU corksport is holding for me. So next paycheck I will be tapped out on cash also :(
Çlark
jaydog5678
Re: Protege transmission question.
Post by jaydog5678 »
MechaManZero wrote: The Ford Escort GT seems to have one in the early 90s. Does anyone know if it would work.
I have one as well and it may work. You would need the plug that goes into it and figure out the wiring. Cut the factory harness and splice into the Fords plug but you'll need to know what wires do what. That shouldn't be too much of a hassle if you have a few wiring diagrams. 8)
MechaManZero
I remember reading about the speedo probs with the v6 speedo. thats why I asked about the ford one. I just swapped a complete Protege wiring harness in my car, will the electric speedo still work. Is it part of the harness or is it seperate?
Çlark
ariesdude
Post by ariesdude »
I think 93+ mx-6 has electric speedo sensor and it will fit the protege tranny.
94 Mx-3 Precidia
MechaManZero
Is the speedo wiring part of the 94-95 MX3 wiring harness cause I took that out and I put the protege one in.
Çlark
ariesdude
Post by ariesdude »
I am not sure - but my assumption is that it shouldnt be part of the harness.... because the speedo wires go directly to the gauge cluster... Do you have one unconnected connector hanging around in the engine bay?
94 Mx-3 Precidia
MechaManZero
Um cant tell cause when I took the harness out to swap the protege one in I still had my accesories harness in there.
Çlark
jaydog5678
ariesdude wrote:I think 93+ mx-6 has electric speedo sensor and it will fit the protege tranny.
It will, but pray to god that it doesn't break the gear off the end and fall into the bottom of the trans. I've had problems with running that speedometer twice.
The harness for the speedometer is part of the main relay harness. The main computer harness for all the different sensors is seperated from that. If you swap the relay harness from the 90-94 Protege, the speedsensor connector will no longer be there because it uses the mechanical type.
MechaManZero
so keep the mx-3 relay harness??
Çlark
jaydog5678
MechaManZero wrote:so keep the mx-3 relay harness??
Yes. I can't think of a reason why to even swap it. I'm still using mine.
I would give the ford's speedometer gear a try if all the info is there. I haven't researched it, but it looks promising.
ryanlindenberg
Post by ryanlindenberg »
the mx3 sensor will work if you make a 1/2 inch shim.
http://www.mx-3.com/phpbb2/viewtopic.ph ... eed+sensor
CARDOMAIN WITH UPDATED PICS
Rayted_m
Post by Rayted_m »
i had the same problem and i dont think it will work to get a ford's speedo gear but try getting the sohc one because that works.
**~Rayted-M~**
Team **~N.M.E~**
**~CROWN LEGION~** Caloboration
MX-3 Civic head light conversion
http://www.cardomain.com/ride/688645
jaydog5678
Rayted_m wrote:i had the same problem and i dont think it will work to get a ford's speedo gear but try getting the sohc one because that works.
Why won't the Ford Escort GT's work? It's electronic unlike the Protege's. You would need the plug from the Ford's harness and cut it a couple inches back. The rest is all simple cut/splice wiring. The SOHC's were all cable driven, so that won't help with a conversion.
