july 15th solo II event
lol chances are you'll do well,Marlon wrote:i'm gonna try and make it
i'm gonna get killed in C - Modified Class, but it;s all for fun
hey in your pm it says your parting out your car. is this true?
Bochek
Adam Bochek's 93 1.6L SOHC http://www.bochek.ca/car.gif
they let you do 2 driver per car, you just run the car 2 times every round.fieromx3 wrote:well i might go....in my bros car hes gunna try to take the day off
Bochek
so its within 5 days now, lets hear a comming/not comming / pending.
Bochek
Bochek
I'm still pending
People comming
Bochek
Marlon
ProspectMx3 - Pending
Boris - Pending
if anyone has a digital video camera, please bring it. we need some video footage. It should be a good event. Id love to see a ze take out a lotus.
Bochek
Bochek
Marlon
Boris - Pending
Bochek
yes you can
- jschrauwen
I don't believe that Adam picked the days on which these events occur. It's done way ahead of time by a number of collaborative organizations.
1 May 28th, 2006
2 June 11th, 2006
3 August 12th, 2006
4 July 15th, 2006
5 July 30th, 2006
6 September 8th, 2006
7 October 8th, 2006
1 May 28th, 2006
2 June 11th, 2006
3 August 12th, 2006
4 July 15th, 2006
5 July 30th, 2006
7 October 8th, 2006
was that in responce to something?jschrauwen wrote:I don't believe that Adam picked the days on which these events occur. It's done way ahead of time by a number of collaborative organizations.
1 May 28th, 2006
2 June 11th, 2006
3 August 12th, 2006
4 July 15th, 2006
5 July 30th, 2006
7 October 8th, 2006
Sorry, I can't come...it's my fault. I decided since I had the day free, to change my bushings on my lower control arms, well, besides for the seized stabalizer links, which were fortunate to be in stock at Mazda St. Catherines, however one of the bolts to the rear mount of the control arm on the drivers side won't come off, it's loose however. I'm guessing the nut inside the frame came loose, so it's not securely fastened, and considering that the car will be pushed, and most of the stress will be on the front end, it's a really bad idea to go. You have no idea now pissed I am. I should of known better, I should of left it as is until after, knowing my luck...god dammit!
