GS power dimming
Car Stereo/Alarm Discussions
vasilaar
GS power dimming
Post by vasilaar »
hey, i haven't actually run into this problem yet, (because my gs is on blocks), however i've had this problem with previous cars.
i will be installing a decent sized stereo,
most likely a pair of 12's probably JL w3v2 (keep it simple)
and i'll deffinatly be upgrading the speakers, and possible adding another set where i can fit them.
i'll be running 2, maybe 3 amps.
i don't think the amps will pull more than 80 amps
but i'll also be putting on a set of aftermarket foglights
and maybe more electrical drain, but i can't think of anything else rite now.
so.... will the stock ALT support this setup?
i'm assuming not.
i am already anticipating installing a second battery and a CAP
(as i have done this in both my old sunfire and saturn)
but are there any upgrades that can be done, with either a BEEFIER ALT, or is there an easy way to install another one?
has anyone done anything like this?
thanx
Drive it like you stole it.
Custommx3
Site Administrator
Post by Custommx3 »
You can upgrade to a Millenia ALT, its 120A over the 90A stock.
Im running 2 amps in my RS off of a 70A Alt and a 1 Farad cap, with no problems.
vasilaar
Post by vasilaar »
sweet... thanx i'll probably upgrade when i get the chance
hgallegos915
Post by hgallegos915 »
capasitor??
-hec
vasilaar
Post by vasilaar »
thanx... i'll probably try to get a beefcake cap. i usually run a 1 farad, plus an extra battery, but i find that its still not enough, mind u i do listen to my music loud for extended time periods, but meh. i think i'm gunna go with the bigger ALT when i get the chance.
thanx again
sk8erdude802
Post by sk8erdude802 »
Im running two amps and two 12's on the stock GS. No dimming yet and I crank it pretty hard most of the time. Id hold off on upgrading all that until you were sure your alt wasnt going to handle it, unless you just feel like doing all that anyway.
Steve-O
93' MX-3 GS SE ZE - Sold to Acheron1502! SOLD!!!
93' MX-3 GS SE - R.I.P. K8 with Integra CAI, HEI mod, Koni inserts with H&R's,drift kit, Kicker KX400.1 and KX200.2 amps, 2 kicker 12s, set of 6x9's. Custom trunk enclosure
MyFeedBackThread
^^^^^ Click on image for my work log ^^^^^
vasilaar
Post by vasilaar »
well good to kno.... as i said... i don't kno if it will happen with the mx3 yet... its not on the road (and not in the same province as me) yet... but i've run into this problem before... and just wanted to see if n e one else did... so far i'm liking what i'm hearing..
thanx again
alleycat29
z
Post by alleycat29 »
i have a problem sometimes with my dimmer switch it goes low sometimes when I accelerate... any ideas
Custommx3
Site Administrator
Post by Custommx3 »
Could be a weak alternator or a wire connection or grounding issue.
Return to “Car Stereo/Alarm”
