.adr file for tuning (help)
stoker100
Post by stoker100 »
just some background info, im an old KLZE owner who mainly chats on probetalk, i need some information and am trying all the possible relative forums for it.
a .adr file is used by software like tuner pro to automatically show the fuel/timing maps etc and makes it easy for changing. Well i recently purchased an emulator and have been manually editing the files with a hex editor and uploading after the change. its not the best way to do it so im wondering if anyone has every created a .adr file for the MX3 or MX6 engine. im aware there are not many tuners out there and its hard being kinda the first to be doing this.
if anyone has a easy list of where all the maps are loacated (by address) or the .adr file that they could send me it would be greatly appreciated. Otherwise ill be laft to manually find them all again and work out how to make an .adr file
KLZE powered 94' probe MTX, MS1V3, MSD, intake/exhaust, rebuilt etc etc
viewtopic.php?f=21&t=79905&p=611207
stoker100
Post by stoker100 »
::bump:: anyone?
kiwi_MX3
Location: Backpacking in Canada in vancouver 13march onwards
Post by kiwi_MX3 »
I run standalone ECU which does all this for me, sorry to say
most peaple on here either run stock ecu's or ms.
good luck and hope you have a big coffee pot.
stoker100
Post by stoker100 »
looks like ill be making it myself, i already started and i know its not too hard, i know where 90% of the information is and how to modify it but im just lazy i guess, still not as lazy as the MS people tho.
nightnic
Post by nightnic »
Why dont you use the tunerpro then? It shows addresses, can search for possible map locations and has hex editor as well if you prefer :)
stoker100
Post by stoker100 »
tuner pro needs the same thing (.xdf) so i still have to manually find all the maps and tell the software where they are. ill be doing this soon from the look of it.
