Mx-3 GS with FE3 Swap Turbo
Bo0sted_Rafi
Post by Bo0sted_Rafi »
Well, here again my friends, last time i've post here, i got my Mx3 GS with BP from a kia sephia and a custom turbo system. 273whp @ 17psi stock internals
I got a problem with that engine because i hit the oil pan with a rock and everyone knows what happens without oil.
Then i start my new swap, FE3N engine 2.0 dohc from a Ford Telstar (626) in NZ. The engine its completely stock internals, only vics removed and turboed with a microtech engine managment, Hybrid turbo TO4E .60 trim with .63AR stage 3. 880cc injectors, Bosch fuel pump, 3/8 fuel line from the tank to the fuel rail,etc
Last monday, we went to the dyno and here its the results
393whp with 331 of TQ @ 25 psi of boost. I will make some modifications for the next time in the dyno to get the same results @ less boost
Here is the video @ dyno
http://www.megaupload.com/?d=X25H9FB5
Enjoy it
Something different
atlantamx3
Post by atlantamx3 »
:shock:
MOre pics/ info please!
~Perry
Please visit
http://www.mx3-atlanta.com
PATDIESEL
Post by PATDIESEL »
Your link is a redirect to some casino site.
Looks awesome though. Seems like alot of boost for only 400 HP. :?
I bet that thing is a tire burner from hell. 8)
Bo0sted_Rafi
PATDIESEL wrote:Your link is a redirect to some casino site.
I Know what u trying to say, but remember, the engine its completely stock, like i said, i make some mods for make the same whp @ less boost. If u got a bp engine with stock internals, u need almost 20psi to get 300whp and if u got a fine and profesional tunning, u blow your engine. Any BP engine with stock internals make this whp and psi of boost.
Bo0sted_Rafi
osargeant
Post by osargeant »
Congrats Rafi, I am always impressed to see 300+ whp out of any turbo MX3. How does the 2.0 F3 motor compare to the BP engine that you were using before?
Furthermore, how in the hell do you drive this thing with so much power, right now I am at 12psi on my 1.6 MX3 and it is a handful on certain roads.
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
Bo0sted_Rafi
osargeant wrote:Congrats Rafi, I am always impressed to see 300+ whp out of any turbo MX3. How does the 2.0 F3 motor compare to the BP engine that you were using before?
If i compare the FE3 with the BP, its very different to me, its has more powerband, more revs, stronger with stock internals and if i want, i can make a stroker with the 2.2 turbo crankshaft.
I drive @ low boost in the street, i dont know how its response with full boost for now because, thats i will do in the racetrack
rebel2k4
Post by rebel2k4 »
Looks great man. :)
98 Ford Ranger 3.0L
mitmaks
Post by mitmaks »
nice work man, thats gotta be fun street car
Limegreen mx-3
Re: Mx-3 GS with FE3 Swap Turbo
Post by Limegreen mx-3 »
Bo0sted_Rafi wrote: FE3N engine 2.0 dohc from a Ford Telstar (626) in NZ.
By any chance could u send a link or # as to where 2 buy a FE3. My brother been looking for one in the US but nobody seems to carry them anymore. My bro want to swap a FE3 in his MX-6 GT. the shop we go to he can't find them anywhere. thanks if u could point us in the direction to find one. Love what u have done to the MX-3 frecking sweet.
Bo0sted_Rafi
O bought it here in PR in a Store called Tokio Motors. if u want to know somewhere u can buy it, enter in mx6.com , there is the information that u need
Thanks
Minimonster
Post by Minimonster »
Congrats on the project. I am looking to get another fe3 motor also. I can't seem to find them any where any more. I have a new goal on MX-3's I want to do 3 eventually. each with a BP (in progress), an FS and an FE3. I know I am crazy.
Proud builder of
455 hp Miata 10.98@125mph
MX-3 RS 25 psi 451 hp
MX-6 F2T 12.8 @ 112 mph
(Current Project) A 700 hp MX-3 now at 475 hp
atlantamx3
I think a version the Kia Sportage had that motor... right?
~Perry
Please visit
Nice! I'm glad to see some with an idea and actually follow through. I think I probably gave you a hard time when you asked about it, more likely cause newbies like to come around and ask about cross-breed swaps, to which I've never seen one done, until now. I take back anything I said, and give you props for the work, you ahd the skill and the knowledge to pull it off. :welder: :2thumbsup:
So what was the work like putting it in? The mounts, fitament, the tranny and axles and stuff? I'd really like to hear how it all came together. Too bad you had that background music in the video, I would of really liked to hear how she sounds...
FE
The 2.0 L (1998 cm³) FE was very different with a square 86 mm bore and stroke. It was an 8-valve SOHC engine for front-wheel drive and real wheel drive pickup use. Output was 83 hp (62 kW) for the carburetor version, or 93 hp (69 kW) with fuel injection.
Applications:
1983-1987 Mazda Capella/626
1985-1987 Mazda B2000
Mazda MX-6
1983-1987 Mazda 929
[edit]
FET
The 8-valve turbocharged FET version of the FE produced 116 hp (87 kW) and 137 ft·lbf (186 N·m). The Japanese variant of this engine was dubbed the Magnum Turbo.
Applications:
1984-1986 Mazda Capella (Japan)
Ford Telstar turbo
1986-1987 Mazda 626 Turbo
Mazda MX-6
Ford Probe
[edit]
FE3
The FE3 was a DOHC variant of the FE. Officially called the FE DOHC, it was used in some European and Japanese Mazdas, but no American or Australian ones. However, it can be found in the U.S., Australian, and other 1995+ Kia Sportage. It can be fitted with a crankshaft from the F2 to produce 2.3 L Stroke, but there are numerous problems with this conversion including requiring aftermarket pistons. Engines with a black rocker cover are 1.8 L, while those with a gold cover are 2.0 L. There were at least six different FE DOHC engines available.
A high-compression variant of the FE3 exists but the only truly distinguishing mark is the domed pistons inside the engine. Factory redline was 7000 rpm but well made examples with aftermarket engine management and better valve springs are seeing continued 8000 rpm usage.
You are right, 1995+ sportage....lol, 300hp sportage
Bo0sted_Rafi
Minimonster wrote:Congrats on the project. I am looking to get another fe3 motor also. I can't seem to find them any where any more. I have a new goal on MX-3's I want to do 3 eventually. each with a BP (in progress), an FS and an FE3. I know I am crazy.
Yup, u r crazy if u want make 3 projects almost if u got the $$$$
Return to “Forced Induction”
