zetec in a mx-3?
forcedairram
zetec in a mx-3?
Just wanted to let everyone know that the sleeper is getting a bumpup in displacement, muahaha. My sister wrecked her zx-2, unlucky for her but lucky for me, if everything checks out OK im dropping it into my mx-3. Yippie!!!
http://www.cardomain.com/ride/1404826
BROKE DOWN POS
BROKE DOWN POS
WingleBeast
- Limegreen mx-3
good luck fitting that motor in. i hated swaping that engine in a ford contour i thought it was a POS but i just didn't like the way ford placed that engine in the engine bay. i just swap the same engine with a replacement.
forcedairram
wow
That sounds exactly whats wrong with the one in my sisters car, eshaust mani is sitting in the middle of the radiator and valve cover is cracked, either of which is easily replacable.
BROKE DOWN POS
BROKE DOWN POS
forcedairram
motormounts
motormounts are easy to custom make, I cant see any complicated issues in the swapping process, seems like all the mounts are in realativly the same places on both the bp and the zetec.
BROKE DOWN POS
BROKE DOWN POS
- Limegreen mx-3
that BPT has better potincal that that zetec engine. replace the enginme with a n/a bp.
- Limegreen mx-3
ITS not like i have seen the swap before there is a fellow mx-3 where i live that did that b5-ze. 2nd gen protege right. i still kick his a--. its not like am dising the guy for doing a different swap than normal.xmaster19 wrote:A Zetec would be out of the ordinary mx-3 swapper route. Try to guess why I have a B5-ZE...
Re: motormounts
How about tranny, axles and wiring, etc...forcedairram wrote:motormounts are easy to custom make, I cant see any complicated issues in the swapping process, seems like all the mounts are in realativly the same places on both the bp and the zetec.
WingleBeast
if the vavle cover is cracked and the exhaust manifold is qeustionable, then befor you swap take the head off and have it and the block tested for being level. cause if it hit the engine hard enough to crack the valve cover the head prolly isnt sitting correctly on the block, causeing all sorts of trouble.
forcedairram
parts
all of the mechanical parts will be swapped with the zetec, as far as electrical goes why use any stock computer when I can drop in a standalone in the same amount of time? and actually i believe that the zetec has more potential that a na bp, as far as a bpt already been there and f@$%ed up just about everyone around here with it, although it was a 16 g turbo and a standalone, as far as ordinary, who wants to be ordinary, I enjoy the challenge of being different. havnt really seen to many people with a zetec engine in a mx. Not to say I wont install a giant turbo in the future, but for now ijust want to see how fast I can get the stock zetec
BROKE DOWN POS
BROKE DOWN POS
I always hate arguing on the internet, but you are nuts. The Zetec is newer and has a much larger aftermarket and manufactures research and development into it. I read a while ago in one of the varried tuning magazines i used to read (i forgot which one, i want to say turbo but it was an N/A buildup) but they cranked about 300 hp out of a N/A zetec and there was still room to pull more out of it as well.Limegreen mx-3 wrote:that BPT has better potincal that that zetec engine. replace the enginme with a n/a bp.
They can be turboed really well too, hell there are more off the shelf parts for this thing than the BP.
-torp.
I don't own a Mazda.
- Limegreen mx-3
iam into mazda's or any type of import. not much of a fan on dom. so my knowege is limited in that area i now enought to work on them but ford in not my biggest fan torpedan. but am not going to argue or this subject. newer tech. & engines are better than the old. so am up to knowing new things.
- atlantamx3
- MechaManZero
I bet there hs been a weird swap here and there on an mx-3. i wouldn't doubt it. Nice that you got a complete wrekecked car with all your needs to parts. But good luck. It ain't gonna be easy stepping into the so called fog of swaps for the mx3.
Çlark
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
