HP from pulleys
boywithamazda
HP from pulleys
Post by boywithamazda »
I'm installing an OBX underdrive pulley and removing and bypassing the a/c.
What can i expect to gain from this?
93 mx3 gs-ze, kl31,headers. other exhaust stuff. Intake harvested from a dumpster.
hgallegos915
Post by hgallegos915 »
You wont feel that much of a diff.. im guessing like 1 or 2 hp? the underdrive pulley can get annoying because it doesnt et the alternator charge battery right. I have one on my maxima and i have tio keep it at a bit of higher idle. I DID feel a difference in the maxima but thats a 3.0 v6. On the mx3 i doint think u will notice much. Make sure you shave off those small trimmings from the oil pum pump casing. The belt.. as for a 94 probe gt without ac. :)
-hec
MX3newbie77
Post by MX3newbie77 »
Be careful with that thing . . . http://www.overboost.com/story.asp?id=1283
kiwi_MX3
Location: Backpacking in Canada in vancouver 13march onwards
Post by kiwi_MX3 »
Well consider that the stock pulley weights in at a hefty 2.5kgs
and my under drive one at .960grams, id say every little thing add's
to the overall gains in the long run.
As for harmonics, they are not a issue, balance is!
Yoda
Post by Yoda »
On a dyno I found the best gains were made when using a stock sized crank and alternator pulley and bolting on only a under drive P/S and W/P pulley. Even then the average was about 5-7whp. Removing the waterpump completely yields the most gains. This plus underdriving the P/S at about 4500rpm at redline yields about 13-15whp @ 6500
