I am in need of an ignition control module for a 4 cyl.
It is a very small part located below the coil.
Here is a picture.
[img]http://www.partsamerica.com/ProductDeta ... tset=A[img]
[WTB] Ignition Control Module
If you dont want to buy it new and If you want to upgrade your ignition system for cheap -
http://www.clubprotege.com/wil/howto/hei/index.htm
94 Mx-3 Precidia
Yes i have - mine is a DOHC so i had to open up the disty and take the coil out. Its really easy in SOHC i think.
94 Mx-3 Precidia
I'm parting out what I can't use from my wrecked 92 rs. Included in these parts is the coil and ignition control module. The engine had good spark and ran when i began taking it apart. I'd sell and ship the ignition control module, coil, and the mounting bracket, for 30, one-third of the cost of a new module at AutoZone. If you'd like pics, pm your email address, and I can send them Tuesday.
93 GS, ATX to MTX swap, chrome 16x7, upper strut bars, SRD LCA bushings.
Upcoming improvements: Tokico/Eibach struts/springs, energy suspension LCA bushings
94 RS MTX, Engine swap completed, ALIVE Again!
95 RS ATX, parts car/project X
I tried the HEI module and failed.
I hooked it up like this:
W-ground
G-orange wire from 4 pin distributor plug (sohc)
C-yellow/blue wire from the 3 pin plug connected to the ICM
B-green/white wire from the 3 pin plug connected to the ICM
I can only assume that I did this wrong because I still do not have spark.
So.....after the endless rain we are having here, I will change to hook at to:
W-same
G-same
B-blue wire from the coil
C-blue/yellow wire from the coil.
Any other suggestions?
Thanks
W-ground
W-same
G-same
Thanks
