I JUST CHANGED MY THERMOSTAT/GASKET AND THE LITTLE HOSE JUST BELOW THE THERMOSTAT ( THE HOSE HAD A HOLE IN IT). NOW WHEN I DRIVE THE CHECK ENGINE LIGHT POPS ON. I'M THINKING I HAVE A BAD SENSOR. ANY SUGGESTION I NEED HELP WITH THIS ONE.
I HAVE A 93 RS
cHECK ENGINE LIGHT KEEP TURNING ON
IF LIFE DOESN'T OFFER A GAME WORTH PLAYING, THEN INVENT ONE.
- relisys_3200
Juggalomastaxx
TRY THIS ONE FOR THE 4 CYLINDER
http://www.eunos30x.com/info/CEL%20Code ... mplete.pdf
AND THIS ONE FOR THE 6 CYLINDER
