possible head gasket prob?
hey all i have a 94 mx3 and my prob is that it over heated and i checked everything and i changed the timming belt cause it was really loose after that so after i changed it she still wont start. it trys but nothin i got it to start once but it sounded like it was flutterin when i hit the gas. so could it be a gasket or the head? cause if this is going to take alot of money i might as well go for a bp motor and rebuild it with performance parts then if this motor is fried. but i wanted everyones opinion on this. and where can i get the parts to rebuild if its not expensive im on a tight budget so any advice would be appreciated from u engine masters here thanks.
- ryanlindenberg
look for coolant in the oil and oil in the coolant. you could also try to pull the ecu codes since the light came on.
CARDOMAIN WITH UPDATED PICS
- MechaManZero
yeah it wass all the way p it the red and there was no sign of coolent in the oil or vise versa. how can i pull the codes when the engine wont start? i put a new timing belt on it and still nothin. but i did get it to start once but it sounds like shat. it flutters and shakes a little its not smoth at all but if i shut it off then i cant restart it. it trys but nothin and if it does start i have to wait again to try the next day then it will. and when the check engine light turned on i felt the car jerk like it just lost alot of power all of the sudden
Just to state it for the record, your motor might be screwed. Even with severe over heating its possible you wont have oil get in the coolant or vice versa, there are just good chances of it.projectmx316 wrote:yeah it wass all the way p it the red and there was no sign of coolent in the oil or vise versa. how can i pull the codes when the engine wont start? i put a new timing belt on it and still nothin. but i did get it to start once but it sounds like shat. it flutters and shakes a little its not smoth at all but if i shut it off then i cant restart it. it trys but nothin and if it does start i have to wait again to try the next day then it will. and when the check engine light turned on i felt the car jerk like it just lost alot of power all of the sudden
You need to do a compression test on your motor. This will let you konw if the motor is either A) trash or if B) the head gasket is blown or the timing is way off.
-torp.
I don't own a Mazda.
