well lets see..
300.00 - Screen
150.00 - motherboard
75.00 - Memory
150.00 - Harddrive
150.00 - Secondary Harddrive
200.00 - Power supply
40.00 - DVD drive
50.00 - TV tuner card
75.00 - Rearview camera
50.00 - Wireless card
75.00 - GPS
65.00 -XM direct unit and PC cable
20.00 - Bluetooth adapter
30.00 Bluetooth headset
30.00 PCI riser card
= $1460.00
Probably alot more after you buy GPS & OS software.
Needless to say all those arent needed, but Ive been working on this close to 3 years now.
This doesnt include the amp, speakers, nor cables.
Also keep in mind, several years of trial and error to tweak and get the bugs out.
Car PC
The nice thing about CarPC's if that you can configure it as you want, depending on what you want. You could literally bgo buy a used Pentium 3 computer (of of the Dell slim Optiplex PC's) for cheap, buy an LCD monitor and an A/C inverter and there you go. (This is similar how I started out and built on). Than you can build on to it from there. Add functionality as you see fit and even upgrade to a small form-factor pc later on, or build your own.
