best place for o2 sensor??
Ok with my setup i have the option to run the o2 sensor on the manifold or on the downpipe...so what would be the best place to run it to get the best air/fuel readings??
So it is basically before or after the turbo??
- ryanlindenberg
if you have a turbo, it should go after the turbo. the manifold temps are too high pre-turbo.
CARDOMAIN WITH UPDATED PICS
- babyblueMX3
yup defenitly couple of feet after the turbo and before the cat
RIP 400whp ZE-T MX-3
- XxantwawnxX
What if ya have one of those loong feed pipes (like us v6 owners have to do,since we have the turbo where the battery is) would it still be to hot to have it put in further down on the feed pipes after the two banks are murged? Since its pretty far from the manifold.
![Image](http://members.cox.net/antwawnhayes/Mx3comavatar.jpg)
- XxantwawnxX
Ok is this only for wideband o2 sensors? because i checked out the pipes being made in the v6 turbo kit thread..and the bungs for 02 sensors are before the turbo (on the headers, or just after)
- mr1in6billion
- Shades
Wouldn't you want it on the manifold to get the best reading as soon as possible so that the computer can figure out what it needs to?
![Image](http://i491.photobucket.com/albums/rr275/Spudsicles/BannerFx.jpg)
"Do it ONCE, do it RIGHT!"
Well, we made this configuration as close to the original non turbo as possible.
Engine - Manifol with o2 sensor and wastegate- turbo - Intercooler - bov - tb.
The O2 sensor was located at the original manifold, as well as the EGr pipe
Air filter - MAF - turbo
Thinking about placing the MAF like this:
AIR FILTER - TURBO - INTERCOOLER - BOV - MAF - TB - INTAKE MANIFOLD
- babyblueMX3
02 sensors are made to be used in a certain temp range. Close like that is too hot.Shades wrote:Wouldn't you want it on the manifold to get the best reading as soon as possible so that the computer can figure out what it needs to?
these normally are for stock 02 sensors.XxantwawnxX wrote:Ok is this only for wideband o2 sensors? because i checked out the pipes being made in the v6 turbo kit thread..and the bungs for 02 sensors are before the turbo (on the headers, or just after)
I spoke with Abe and we'll weld a 02 bung in the downpipe for those running with a wideband.
