Precidia door leak
Precidia door leak
Hi everyone,<P>Did anyone experienced door leaking on 94 Precidia. I noticed that my door was taking water when changing the passenger speaker (the water was pouring out of the spkr casing). the bottom of the door is not rust so I think it could be the seal around the window. Any ideas, suggestions???<P><BR>Thanks
Re: Precidia door leak
Seal around the door, might be it. Mine is loose..
I'll try to fix that ASAP. I notice once that some water was coming from the passenger, and there was a little of water coming in. But if the water is in the door... Jeez, I hope you don't have a cold winter as I will have
The Mx-3 is my daily, so it will live in the snow for a while.. Ice in the door, I won't permit that...
Manach
Ex Mx'er with a Mx-3 1993..
Still in the Mazda Familly with :
-Mazda Rx-7 1987 GXL (Not running, one housing does not compress)
-Mazda Protege MazdaSpeed 2003.5 Titanium!
Still got 3 Engines!
- B6-ZE : Turbo Festiva project (Waiting donor car)
- BP-DE : Trader for a B6-ZE 1994 for parts upgrade in the Festiva project
- K8 : For sell. Pm me for info!
Once you go turbo, you can never go back!
See post “Panel door wet (speaker)” in the CAR STEREO/ALARM forum. You will find more on this topic. Thanks for your reply
