klze running Centerforce Stage I anyone running?
just curious if anyone was running this clutch on there klze motor?
How does it feel? Any slipping at all?
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- vozaday2000
i'm running the centerforce dual friction with the klze and it seems to grab nice. it doesn't let off as fast as say a clutchmasters but it has a tight but almost stock feel to it. nice for a daily driver.
http://www.cardomain.com/memberpage/730367 - UPDATED!!!!!!!
'94 MX-3 GS KLZE, KL01 Cams, Fidanza Flywheel, Centerforce Dual Friction Clutch, WeaponR Ram Air, 2 1/4 exhaust, Nichi Neptune Rims, Toyo Proxy 45 Rubber.
![Image](http://memimage.cardomain.net/member_images/10/web/730000-730999/730367_31.jpg)
- solo_ryder
- atlantamx3
atlantamx3 wrote:Brian,
I think Chanko and/or Chris may have the Centerforce as well.
I say just go with the SPEC Clutch, my man!
Chanko might be but i know chris is running the Clutchmaster Stage IIR as thats the same one i was running cause we were talking about how it feels pritty near stock.
I would of went spec option BUT time frame and $$$ are always a problem so i had to go centerforce, i know the clutch will work fine as people are running excedy clutches with there ze swaps and they seem to be handling pritty decent so this time i just need to make sure i adjust the clutch pedal height to make sure the clutch fully engages and disengages
- solo_ryder
I hate to resurrect an old post, but I'm curious. I've seen clutches labelled as mx6/mx3 and then clutches labelled as mx3. Can I use a clutch that is meant for an mx6 in my mx3? I was told that the mx6 and mx3 flywheels are interchangeable, so I thought the mx6 clutch is probably the same size, right?
KLZE/KL31 ecu/Pacesetter headers/track pipe cat delete/2.5 inch custom exhaust out to fart pipe/warm air intake for now
/Fidanza 9lbs flywheel/Stage 2 kevlar road racing clutch which still slips/stock wheels/BFG KDW-2 tires. Looks bone stock ![Wink ;)](./images/smilies/icon_wink.gif)
There are those who claim to be street racers, and then there are those who claim the streets for themselves. I am not a street racer. I am a StreetSweeper.
http://www.streetsweepersracing.com
- Yoda
I had a CF/DF clutch but as I found out the hard way they have a problem with the weights on the diaphragm fingers breaking off and becoming flying shrapnel inside the bellhousing. Damaged the input shaft, throw out fork and clutch disc. The standard CF clutches should be as bad as they don't have weight on the fingers to increase clamping force.
- Yoda
I don't think there is anything special about the pressure plate. The ones I seen just look to be a resprayed Dakin (Korean made OE) pressure plate. Even the DF just seemed to be a Dakin with weights on the diaphrgm fingers held together with a steel hoop.
solo_ryder wrote:The pressure plate design on those centerforces are pretty sweet, I can snap some pics of the clutch and pressure plate and post them later if you want... The damn thing didnt come with a alignmetn tool, pilot or throwout bearing though..
No. A true MX3 clutch is 10mm smaller diameter. But the K8 flywheel has enough surface area to accomodate the larger MX6 clutch.Teqnyck wrote:I hate to resurrect an old post, but I'm curious. I've seen clutches labelled as mx6/mx3 and then clutches labelled as mx3. Can I use a clutch that is meant for an mx6 in my mx3? I was told that the mx6 and mx3 flywheels are interchangeable, so I thought the mx6 clutch is probably the same size, right?
- jschrauwen
I'm currently using an MX6 clutch with MX3 tranny and flywheel on a ZE. Engaging point changed (sooner) when it was put in but I attribute that to the difference from the original oem one that had 260,000km's on it.Teqnyck wrote:I hate to resurrect an old post, but I'm curious. I've seen clutches labelled as mx6/mx3 and then clutches labelled as mx3. Can I use a clutch that is meant for an mx6 in my mx3? I was told that the mx6 and mx3 flywheels are interchangeable, so I thought the mx6 clutch is probably the same size, right?
So, are the mx6 and mx3 flywheels different, size wise? I have always been told that they were exactly the same.
Yoda wrote:I don't think there is anything special about the pressure plate. The ones I seen just look to be a resprayed Dakin (Korean made OE) pressure plate. Even the DF just seemed to be a Dakin with weights on the diaphrgm fingers held together with a steel hoop.
So would it be better vaughn if i were to use the pressure plate from my Stage II clutchmaster clutch?
- vozaday2000
mmm.... maybe i should worry about that.Yoda wrote:I had a CF/DF clutch but as I found out the hard way they have a problem with the weights on the diaphragm fingers breaking off and becoming flying shrapnel inside the bellhousing. Damaged the input shaft, throw out fork and clutch disc. The standard CF clutches should be as bad as they don't have weight on the fingers to increase clamping force.
- solo_ryder
The CF stage 1 also has the counterweights on the pressure plate fingers with the steel ring around it.Yoda wrote:I had a CF/DF clutch but as I found out the hard way they have a problem with the weights on the diaphragm fingers breaking off and becoming flying shrapnel inside the bellhousing. Damaged the input shaft, throw out fork and clutch disc. The standard CF clutches should be as bad as they don't have weight on the fingers to increase clamping force.
