Loud clicking when turning...
Hi there! just wondering if anyone could confirm if i am correct. When ever i make a left turn and its more noticeable when its a harder turn it makes a loud clicking sound. its getting worse and worse. Is this the CV Joint?? I have found some parts on line and just wondering is this the one
A1 CARDONE 60-8024 [CV HALF SHAFT] [CV Half-Shaft Assembly] Reman. Front; Left; w/A.T.
Also how do i know if i have ABS? i have a 93 GS model v6 thanks!
Any help is greatly appreciated
lakersfan1
Yeah. If it's indeed a CV, then it's typically you go to the one opposite the way you turn when it clicks. So if it clicks when you turn left, it's the right CV. If it clicks when you turn right, it's the left CV. Typically, though, the CV won't go bad unless the boot tears. Get under the car and see if either CV's outer boot is torn. If so, that's your Huckleberry.
lakersfan1
mx32nerDOTcom
snellgrove
Yup, what he said... stand on the brake pedalUKMX-3 wrote:You can check if you have ABS by braking really hard and seeing if your wheels lock up!!!!!
I recently took my MX-3 round a track, and used the ABS loads... brake pedal is all spongy now
1997, Silver, V6
CV boot is likely torn...this is a rubber cover over the joint to keep greace in and dirt out. This is what caused your CV joint to fail (or almost fail) Oh, and when your CV joint goes your wheel falls off (almost) So yeah i'd get that one looked into before you end up in the middle of an intersection with a wheel that is basically broke off. LOUD clicking is bad..usually the worse the joint gets the louder the joint will click.
94' MX3 GS atx
93 geo storm GSi
99' Ford ZX2 mtx
2001 honda CBR 600
2000 kawasaki kx 500 MX
93 geo storm GSi
99' Ford ZX2 mtx
2001 honda CBR 600
- vozaday2000
and get it changed quick, it doesn't take long for one to fail. sometimes it takes a year and sometimes less than a week. it is brutal when one fails. it basically makes your engine align with the shaft when you turn. it feels like your car is being pushed off the ground.
http://www.cardomain.com/memberpage/730367 - UPDATED!!!!!!!
'94 MX-3 GS KLZE, KL01 Cams, Fidanza Flywheel, Centerforce Dual Friction Clutch, WeaponR Ram Air, 2 1/4 exhaust, Nichi Neptune Rims, Toyo Proxy 45 Rubber.
