Oil in spark plug hole.
lennis
Hi I changed my oil a couple of hours ago. And I checked the plugs to and I noticed that my plug nearest the oil filling cap where pretty much oil in.
I going to drive the car for a couple of km then check the plug again and se if there is more oil, wiped the oil I found. If I find oil again there is a big risk that my valve cover gasket is broke? right?
Or what could have happend. The car is running smooth when your driving and in idle it sounds god to.
Thanks lennis
Thanks lennis
Mx-3 GS. CAI, dtm rear muffler, H&R spring with camber bolts. Painted interior, rebuilded front with gs lip and splitters. Real supra rear wing custom fitted almost done. blue homemade underkit neon, neon inside, glasfiber glovecompartment with the headunit in. XBOX + 7 inch screen .
hgallegos915
Yeah seems like it. If the oil is INSIDE the combustion chamber could b bad valve seals or piston rings... Most likely is the valve cover if it doesnt smoke.
-hec
hgallegos915
-hec
It takes a BIT longer than 20 minutes to do it right, but can be done.
The gasket is around $100
You will also need sealant you need to put that on the gasket to glue it in.
Make sure you look up the torque specs for the bolts when reattaching the cover and make sure of the proper amounts.
Remember the rear cover needs you to take off the intake manifold too.
You should also replace your spark plugs as they have been affected, and your leads if the rubber on them is cracking (due to the oil).
When I had mine all changed, it make a large difference in power that I did not expect.
- relisys_3200
