Fluctuating idle, bucking and stalling.
I have dropped in on a couple of threads and asked some questions but I think my problems warrant a new thread.
When car is started and engine is cold everything seems fine. Idle stable car normal to drive. Problems only occur once car has warmed up. Once warm the following problems show themselves
- Fluctuating idle
Unfortunately there doesn't seem to be a pattern to this. But it with move up and down from 1k to a point where it will almost stall and then shoot back up to 1k again. Other times it will shoot up to 2k and hold then suddenly fall below 1k and back up again.
- Bucking
Again when car is warm. Car will start to buck and loss power. When accelerator is pushed it will just splutter as though it wants to stall. If you take your foot off and let it coast the bucking and spluttering stops until you put your foot down again. This fault is very intermittant.
- Stalling
Will only happen once car is warm. When idle gets low enough and car stalls it will not start for at least a couple of minutes. Seems to happen more often when stopped on a hill or when clutch is pushed in.
I have searched previous threads and taken advice so far as to what could be the cause of the problems so this is what i have checked so far.
- have replaced plugs
- have replaced spark plug leads
- cleaned distributor
- checked intake lines and hoses, replaced air filter
Any other things I should be looking at?
- Fluctuating idle
- Bucking
- Stalling
- Shades
Check the wires on the battery... I had a similar problem but it was cause my negative battery wire was loose.
Also try adjusting your idle screw. Wait till your car has warmed up first so that you get an accurate reading. It might be idling too low when warmed up. I think stock idle is 750-850 rpm's. As long as you keep it under 1000rpms it'll be alright.
"Do it ONCE, do it RIGHT!"
^ Yeah unfortunately I have tried this and it doesn't seem to have fixed anything. When car is running without faults it is perfectly fine, like nothings wrong. Strong acceleration runs smooth and then other times all of the above faults.
I don't know really getting on my nerves. Can't trust it to drive anywhere.
- cjthor
I would check your IAC valve. Located at the bottom of your throttle body. This is a common problem on the MX3.
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
- Tunes67
Double check for vacuum leaks.. specifically the ribbed intake hose from the air box to the throttle body. Also check the grommet that the PCV valve goes into.. they harden up over time and can allow air past the PCV. If you determine that it isnt a vacuum leak.. then its probably as cjthor mentioned.. your IAC valve is probably gummed up. I did a How To on cleaning and adjusting your Throttle body, including the IAC valve.. Its a 2 thread posting.. Part 2 is in the FAQ section.. but you will need to search a bit to find Part 1 for whatever reason. Best of luck.
Tunes67
Tunes67
Well as I mentioned above I have removed the TB but it is quite different. When I removed the TB the gasket which was there had almost completely disintegrated. Areas around the outside had broken away as well as there being a few cracks right through to the middle. It was difficult to remove since it seemed to be stuck to the TB real good. Anyway here is how it is right now. Still more cleaning to do.
