new engine for mx-3
- fieromx3
new engine for mx-3
ok my stock v6 engine is pretty much fried[edited]. i really want a new one now and soon. does anyone know where i could get an engine for a good price and one that runs perfectly! i checked fnfmotors and corksport but im uncomfortable ordering through them cause i dont know the condition they r in.
[read the rules]
[read the rules]
- solo_ryder
killerpickle
A turbo charged GM ecotec engine? Are you crazy? Like the one from the cobalt maybe? That would cost some serious money. I would not like to be the one to wire that up to our cars
On a serious note, that engine does not impress me at all. A mildly turbo or supercharged KLZE would be more feasible.
Tom Alexander
- jschrauwen
Here you go. Maybe you'll have better luck than me. Don't ask too many questions though. http://www.mx-3.com/phpbb2/viewtopic.php?t=43590
- papa roached
MX-3 = Mazda + Mazda
MX-3 does not = Mazda + GM motor, thats simple
kida like that marriange = man + woman thing
aleros are not really fast + the ze bolts right in the ecotec would take foreverfieromx3 wrote:im not puttin an ecotec in it i just wanted to c what ppl would say to it. we have an alero they r fast the ecotec is an awsome engine. im not sayin a ze is crap compared to it the ze is an impressive engine
to put in.
- MX-3 Money
Ya thats a good way to waste a lot of time and money. Plus you wouldn't impress anyone on here.DavidOS wrote:aleros are not really fast + the ze bolts right in the ecotec would take foreverfieromx3 wrote:im not puttin an ecotec in it i just wanted to c what ppl would say to it. we have an alero they r fast the ecotec is an awsome engine. im not sayin a ze is crap compared to it the ze is an impressive engine
to put in.
1993 MX-3 GS 5 spd, KL-ZE swap, kl31 ecu, 110 amp alternator, Unorthodox Underdrive Pulley, SSautocrome headers, High flow cat, Pacesetter high flow cat-back, B&M shortshifter, Clear Sigs/Sides.
hgallegos915
Ill sell you my k8 for cheap I just bought me a klde. HAs new timing belt and full service done to it.
-hec
- fieromx3
i dont want another k8. my goal for this car is to make power. im not into looks that much i like cars that can perform. i like speed and a hell of alot of power. i want a kl-ze or kl-03 and put a turbo on it and do everythin possible to the engine and squeeze every last bit of horesepower out of it. my main motive for this is because i wanna keep up to my brother with his fiero when he gets a 3.8litre supercharged engine.
Juans_93_MX3
Your stock engine is screwed or you just dont like it?
My suggestion would be to look into places where you live that sell KLDE engines. You might be able to find one with just only 20k miles for very cheap. Or you can get one with alot of miles for a price of atleast $300 and you can end up building it up to for a turbo.
Or you can go for a KLZE...
By the way, your idea about putting a Ecotec engine in a MX3... I am just going to forget I heard that
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- atlantamx3
lakersfan1
