Quick engine oil questions
A forum for MX-West Car Club Related Topics. MX-West has two Chapters;, the original is in Vancouver, British Columbia, and the second is in Calgary, Alberta.
Chiggles
Post by Chiggles »
I know this is probably more of a topic suited to be in the V6 or the General Forums, but this is location specific that I'm more concerned about. I realize 5w30 is better for colder climates, and 10w30 better for warmer. So my question is this:
For those of you in Alberta, what kind of oil are you running year round? I bought my Precidia in November and had it winterized then so it runs 5w30 on it right now, but since I should be changing it again for the spring/summer, should I put 10w30 in given how hot our summers can get, or will 5w30 be good enough for even 34°C weather??
....And while I'm on the subject, I've heard through these boards that although switching to synthetic would be better for performance, there is a risk that I'll have more problems with leaks cuz the additives eat through the minerals caked around the gasket seals or something like that. So... how exactly do I know whether or not a 95 vehicle can handle synth or not besides trial and error? I'm pretty sure synth's never been in the car before, since I'm only the 3rd owner of the vehicle and I know the previous 2 didn't race with it or anything like that.
Basically, since I'm due for an oil change, is 5w30 good enough year round in Alberta weather, or should I go to 10w30 for the spring/summer and back to 5w30 in the fall/winter? Do I stick to non-synth or try switching to synth??? Please help! :oops:
monstar-mx-3
Post by monstar-mx-3 »
When i was in Winnipeg, I was running 5-30 year round. The temp out there go from -35 to + 35 in the summer.
But now that i'm out in BC, I'm running 10w30 because the winters are that cold as they are in AB to MB.
solo_ryder
Post by solo_ryder »
it depends where u are...we had a cold snap here and I was super carefull so I put 5W 30 jus tto be safe, I like how it ran, but for summer maybe a thicker oil cause it will be heating up faster and run harder.
Shades
Post by Shades »
I like to run 5W-30... just cause it's more runnier and gets up the hydrolic lifter quicker than 10W-30.
I also use Higher Mileage oil and an oil supplement to keep the tarnish off the lifters... keeps it from running noisy.
"Do it ONCE, do it RIGHT!"
wyldside
Post by wyldside »
I'd recommend going with a 10W-40 for the summer. This will run nicely with GS especially with road trips. When winter draws near and the temperatures begin to drop, use either a 5W-30 or 10W-30 if you like. The 5W-30 would be better for our nice -40 Deg mornings. If you go with Full Synthetic use Amsoil 20W-50 for the summer and their 0W-40 for Winter. These values are not good in most other brands of synthetic oil since Amsoil has a really low temp pour rate that most can not compair to. I will be using Amsoil 20W-50 full synthetic on my KLZE this summer.
James Gosteli
X-Prez of MX-West
1992 Seal-Gray MX-3 GSR-ZE (KLZE 2.5L V6) :mrgreen:
1992 White MX-3 GSR-ZE (KLZE 2.5L V6) :( Worklog (Parting out)
1993 Blaze Red MX-3 GS - RIP :cry:
jschrauwen
Post by jschrauwen »
wyldside wrote:I'd recommend going with a 10W-40 for the summer. This will run nicely with GS especially with road trips. When winter draws near and the temperatures begin to drop, use either a 5W-30 or 10W-30 if you like. The 5W-30 would be better for our nice -40 Deg mornings. If you go with Full Synthetic use Amsoil 20W-50 for the summer and their 0W-40 for Winter. These values are not good in most other brands of synthetic oil since Amsoil has a really low temp pour rate that most can not compair to. I will be using Amsoil 20W-50 full synthetic on my KLZE this summer.
James, since you did a complete rebuild on the ZE, did that include valve seals. If so than the full synthetic I think would be a good choice. If not than It may be prudent to stay away from a synthetic, again depending on condition of vale seals. Depending on age/miles on ZE, possibility of blow by on the valve seals may increase with the use of synthetic. Tunes and I talkes at length on this, this past weekend.
20w50, that's some pretty heavy (thick) stuff. You must be planning on some serious racing or something.
wyldside
Post by wyldside »
I did replace the valve seal (even though I really didn't need too - they were still pretty good). The Amsoil 20W-50 Series 2000 is pretty good for engines that run a little hotter than average. The Amsoil version of 20W-50 seams to have some pretty good specs to it. I think it will run quite nicely for the summer. I'll see how it works out.
James Gosteli
X-Prez of MX-West
chertel
Post by chertel »
I add lucas oil stabilizer with 5w-30 synthetic but next oil change I think I'll try amsoil 20w-50. Thanx for the advice.
Return to “MX-West Car Club (Vancouver, BC / Calgary, AB)”
