removing ZE heads..
hgallegos915
removing ZE heads..
can anyone tell me PLEASE the name of the tool used to remove the hed bolts..ANYONE? any help appreciated.
-hec
- ccreech
Head bolt removing socket...I know, I know, I am a smart A$$. Its a 12 point 12mm socket. Most sockets are 6 point...meaning that they have 6 grabbing surfaces, so a 12point will have 12.
It Looka Like Dis:
http://www.partsamerica.com That means that Advance has it...probably not on the shelves but they have it.
It Looka Like Dis:
hgallegos915
um I would mimagine you have never removed ze heads? this is what they are..they hyave special sockets and not regular sockets... check it out. I need the name or socket for that job.
-hec
hgallegos915
my bad..there.
-hec
hgallegos915
Ya, um he is tellin you what u need.hgallegos915 wrote:um I would mimagine you have never removed ze heads? this is what they are..they hyave special sockets and not regular sockets... check it out. I need the name or socket for that job.
Get a 1/2" 12 point 12mm deep socket. I had to buy one when i took mine off too.
- ccreech
Um...there is no need to be rude to someone trying to help you.
If your bolt looks anything like this then its a 12 point 12mm bolt. I can't tell because that picture is hard to see. That is one dirty ZE. How many miles were on that thing? If memeory serves me, you have to remove the cams to get to all the head bolts anyway.
Mnemonic
Yep used the same tool he used, man those heads need to be dipped, diiiiiirty!
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
hgallegos915
thanks . Im only taking it out to see what happened with that ze. Its a bad ze was smokign white. bad head gasket mixed with bad valve seals and well high reving. Got it for free I cant complain. didnt mean to be rude. thanks for the info
-hec
hgallegos915
hmm the 12 mm socket does not work o.0 13 is to big.. 12 is to small..but 1/2 fits and slips... any ideas? 13 is way to big..12 small.. and 1/2 inch was the closest.
-hec
hgallegos915
got it.. it was a half inch.
-hec
- jschrauwen
Hector, Hector, Hector. Read what CCreach and Sphynx said...1/2" drive.....12mm deep socket........12sides or edges inside that 12mm socket. Your 12mm is too small because it has six sides or edges to it.
Your not listening Hector. Perhaps because it was free and unless this engine hasn't been f*cked with you should be fine with what the guys told you.
hgallegos915
yeahgot it
I tried 12 and didnt work..that strange.. tryng to get the heads off...as far as the heads sheesh..the valve seals are gone...valve look burned and cams are a bit worn :S i cant wait to remove the crank and pistons.. lol ill take pics. itsvery dirty..needs to defenetly be dipped...the whole thing.
-hec
- jschrauwen
Then it's obvious that this is a pretty high mileage ZE and that someone already has been into the engine and didn't use the correct head bolts...good luck Hector!!hgallegos915 wrote:yeahgot itI tried 12 and didnt work..that strange.. tryng to get the heads off...as far as the heads sheesh..the valve seals are gone...valve look burned and cams are a bit worn :S i cant wait to remove the crank and pistons.. lol ill take pics. itsvery dirty..needs to defenetly be dipped...the whole thing.
