Totaled RS, parting out[FS]
- Flashpoint2
				RaverChankoMX3
What condition is your black interior paneling , specifically the dash, and both door panels?
							MX-3 Owners Club of Atlanta
Clemson Sports Car Club #72
MOCA tuned straight-neck KL-ZE '93 MX-3 GS : Updated: 03/05/06
Alright, the car's in my driveway so let's get crackin'. I made a list of all wanted parts and went and checked them out the best I could. If you PM'ed me, I'm going to try to respond directly to you as well, but I may miss something so everything's covered here as well. Any parts that are wanted by multiple people, I'll be taking best offer. Any parts not listed here, ask for 'em. All prices are without shipping. If my quoted price is too high, tell me about it. Local pickups will receive priority since it'll make it quicker to get everything gone.
Civic projectors: several inquiries; perfectly functional condition, scratches on lens from fitment, all scratches covered by fender once installed, fiberglassed bottom and fully sealed, they don't look manufacturer quality underneath but I'm proud of the work, no mounting brackets, I decided using the bumper as a tension holder worked and looked best providing for a perfectly flush line along the bottom of light (PM/post with bids for these)
Clutch/Brake pedal assembly, Tunes: once it's jacked up, shouldn't be a problem, let me know if you need it and we can talk about price then
Shifter/Linkage, Tunes/mxprecidia: shifter is fine, linkage should be unless it suffered from scraping ($20 shifter, best offer linkage)
Master Cylinder/Clutch Actuator Rod, Tunes: more info once car's jacked up
Strust/Springs: amazingly, they may all be in fine condition, the impact doesn't look like it damaged the rear passenger assembly; about 200 miles of usage, will also include ZX2 thrust bearings that match the Tokico's wider diamater, will ship pre-assembled ($350 obo, assuming perfect condition)
Interior paneling/dash, Raver: interior was nearly immaculate prior to crash, only thing was a rub mark on the top of the driver's door panel; after crash, rear passenger paneling is no good, front passenger is deformed some, I won't be able to tell if it'll be ok till I pull it off (wait till it's off car for price)
Stock headlights, Teal93: cloudy but perfect working order, I don't have the inner adjustment bracket, you'll need to reuse yours ($35)
Black altezza taillights, Dali: the altezzas weren't on the car when I wrecked it, they were lying already damaged in my garage, there's a vertical crack through the lens about 3 inches from the outside of the left one from failing to pry it apart to reseal them ($25)
Front bumper, a few people: The bumper isn't damaged from the crash, but it was hacked on when I installed my projectors; the tension arms have been removed completely; paint's not in great condition, one or two dime sized paint chips gone, the passenger side screw mount on the farthest end was broken when I bought the car, I tapped another screw hole directly in front of it and no one would ever guess ($30)
Glove box door, Insanebabe: perfect condition, but if the person wanting the dash wants this, I will include it for them ($20)
Rear seats, top/bottom, Insanebabe: The bottom was deformed, but amazingly it is still in perfect condition without any tears or anything, just a matter of bending the wire frame back; the top I can't be sure about till I remove it, it's pinned in there pretty good and there may be some damage on the passenger side (wait on price)
Hydrolic clutch assembly, Insanebabe: not sure on this one till I jack up the car and figure out exactly what it is, heh
Driver's side fender, Tovock: fine condition, possibly has very tiny chips in the paint from highway driving, I'll confirm on this later ($50)
Hood, Tovock: three or four parallell large scratches horizontally across the hood from a tree branch scraping it, also positive it has many very small paint chips from highway driving; other than needing paint, it's good ($50)
Main fuse box, Tovock: should be in fine condition, I just need to figure out how to remove it ($10)
Center console, I forget who: it's no good, the passenger seat got pushed in a bit and cracked the console. The console doors are in good condition, though if you want 'em ($10)
Mass Airflow Sensor, Joey: fine condition ($15)
B6 engine, local pickup only: just over 100k miles, tested 85psi in #1 cylinder and 90+psi in others a couple months ago, NGK plug wires changed along with plugs, rotor and cap less than 5k miles ago, Mobil 1 oil change every 3k miles, perfect running condition
That's all I have as of now. If I missed anyone's requests, I apologize, just post/PM me. I think I'm going to edit my original post with this info and updated info, seems the best place to keep it localized rather than this post in the middle of everything. Thanks again guys.
							'95 RS: RIP
						- MX3-Freak
I don't mean to be too off topic, but was that steel rim on before the wreck?
							Stock 1995 RS - Creek Blue
Car Meanins:
						Car Meanins:
- Hoodzy
i wanna cry
1995 Creek Mica Blue GS
- Too much Time
Yeah, so everyone's falling through on there 'interest' so I'm bumping this up letting you all know just about everything is unclaimed. Even bids on the projectors have fallen through. Now I just hope I can make back the $250 it cost me to get the wreck out of the impound and back to my house.
							'95 RS: RIP
