KLZE Gasket
KLZE Gasket
If have a klze engine, i have to change valve cover gaskets. would i just buy valve cover gaskets off of a 2.5L Engine found in a Probe ????
Thanks,
Ryan
						Thanks,
Ryan
- babyblueMX3
any k series valve cover gaskets...k8, kf, kl
they are all the same
mx-3, mx-6, probe, mx-6
RIP 400whp ZE-T MX-3
- jschrauwen
Steve; Who would have the less expensive gaskets - Mazda or Ford? Are they the same item/quality gasket?babyblueMX3 wrote:any k series valve cover gaskets...k8, kf, kl
- babyblueMX3
I think I checked last year and ford was cheaper
i got mine at mazda 81$ for both
- jschrauwen
Wow, that is quite a dispairity between prices and geographies.  It appears to be hit and miss and it's just a question of calling around to local dealerships.  Good to know stuff!!
- jschrauwen
Did a little searching at CT.
Part# VS50426R (Fel Pro) - $171.98cdn/set for Probe and Millennia.
Part# VS50462R (Fel Pro) - $64.72cdn/set for 2.5L '96 Ford Contour, 2.5L '98 Ford Mystique.
Not sure if different part numbers equate to different gaskets but this is quite a price difference.
				Gro Harlem
look it up for the ford probe at autozone or a place similar.
usually the ford probe is cheaper just b/c more were sold, even though its teh same part number.
You shouldn't have to spend more than $40 for a pair of valve cover gaskets
DONATE TO MX-3.COM
						DONATE TO MX-3.COM
yah they are just a type of rubber cheap as hell,
- jschrauwen
More usefull tidbits.  Local Mazda quoted $37.00cdn / each bank.  They also mentioned that some Mazda dealerships don't always purchase/sell Mazda OEM parts as in the case with VC gaskets.  Rather, they sometimes stock/sell replacement parts with the consumer sometimes believing that everything sold by Mazda is OEM.  This may explain the disparity in prices and quality at various dealerships.
- babyblueMX3
ford contour and mystique doesn't have the same gaskets as ours...it's the duratec engine and not a k-series engine...jschrauwen wrote:Did a little searching at CT.
