Cold Air Intake
				skylineracing07
Cold Air Intake
i need a cold air intake for a 1992 mazda mx3 sohc 1.6l
						- jschrauwen
Try going through archives and going through other members suggestions/recommendations.  A good muffler shop can make one  based on your specs for you from scratch.  All you need is the tubing connectors and your desired air filter on hand for the fabrication/install.
