Sorry guys, For those who are confused, This black piece of plastic is in the back of my car and it is is cracked in half . I did not do this, some punk broke it.
You see where the red line is?, thats where it split in half (In the middle) and its the plastic that is right above the middle brake light. Is this replaceable??
Last edited by Mazdaspeed96743 on July 19th, 2005, 1:13 am, edited 1 time in total.
yea, its east to replace, its called a hatch garnish
Parts needing installed: turbo kit from BB (if i ever get it), 9.0:1 CR Diamond pistons, 4340 forged H beam rods, C/J-Spec spoiler, Nissan red tops in KL rails http://www.cardomain.com/id/blazejeremy
