I am selling my
90 MX-6 GT if anyone is interested. Here are some specs and pics...
1990 MX-6 GT, atx, 159k miles, blaze red, charcola/gray interior.
Fully loaded, power windows, locks, power sunroof, factory adjustable suspension, factory rear strut tower bar, 2.2L Turbo.
New paint as of December 2004, immaculate exterior as you can tell from the pics. Interior is in good shape, small tear on the driver's seat, otherwise nice, especially for it's age. New brakes all the way around, new rotors up front. Head gasket job was done about 1000 miles ago, alon with new intake, vc, exhaust gaskets. Car starts fine, runs great, no smoke, turbo spools nicely. Head and turbo were replaced with lower milage ones at the time of the head gasket job.
Mods -
cone filter, 2.5" exhaust from the turbo back including a high flow cat....a-pillar mounted autometer air/fuel and boost gauges. 16" Plymouth Laser turbo wheels with 205/55/16 tires, could use balancing, mesh paint black, also have stock wheels with good tires to include.
Problems -
Small crack on windshield, still passed inspection, good PA inspection until 9-05. Car needs a new rear motor mount, I have a good one to include. Car could use new cv axles, also have brand new ones to give with the car. Exhaust has a slight rattle, probably will fix that tomorrow.
Car currently spools between 9-11psi, depending on outside temps, I have a manual boost controller uninstalled I can throw in. Runs great, very little work left to do to this car.
$1300
For some additional cash, i can provide almost every part needs to swap this car into a 5-speed, including the tranny, all linkages and mounts, wiring, flywheel, etc...have a clutch to go with it, but you'd want to put a new one in there anyway while you were at it...this swap alone is worth at least $500, give me $1500 for the car and it's yours.
Now for the pics...
https://prod.campuscruiser.com/cruiser/ ... htside.JPG
https://prod.campuscruiser.com/cruiser/ ... htrear.JPG
https://prod.campuscruiser.com/cruiser/ ... paint3.jpg
https://prod.campuscruiser.com/cruiser/ ... paint2.jpg
https://prod.campuscruiser.com/cruiser/ ... erior4.JPG
https://prod.campuscruiser.com/cruiser/ ... erior3.jpg
https://prod.campuscruiser.com/cruiser/ ... erior2.JPG
https://prod.campuscruiser.com/cruiser/ ... erior1.JPG
https://prod.campuscruiser.com/cruiser/ ... ngine1.JPG
FS: Mazda MX-6 GT Intercooled Turbo Southwest PA
'99 Ranger XLT Offroad 4.0 4x4
