Probetalk guys sayin different ZEs
Off-Topic Discussions
DavidOS
Post by DavidOS »
http://forums.probetalk.com/showthread.php?t=1701133969
whats your opinions on this different ZE engines crap?
i dont believe the hype.
papa roached
Post by papa roached »
its true, the curved neck ones can be a little bit different, im supermx3 over there
DavidOS
Post by DavidOS »
my compression is 10:1 and with a curved neck.
I highly doubt there is a 30hp difference between ZEs though.
papa roached
i woudlnt say that much, but have heard that some curved ones being in the 185 area
jschrauwen
Post by jschrauwen »
papa roached wrote:its true, the curved neck ones can be a little bit different, im supermx3 over there.
93 MX-3 GS, KL31 camed KL-ZE, Millenia intake, Millenia TB, 9lb Fidanza Flywheel, ACT clutch, Cork Sport SS clutch line, Unorthadox UDP, 255 lph fuel pump, HEI mod, ghetto-charger intake, KL-DE ECU and KL-DE VAF, stock cat, stock mid pipe, Top Speed Pro 1 axel back muffler, Brembo Crossdrilled and Slotted rotors on all 4 corners, 15 inch Konig Heliums
Wasn't hard to figure that out. You get used to frequent poster's profiles and the "KL31 camed KL-ZE and ghetto-charger intake" kinda gave it away "PR".
Although I'm still fairly new to this BB, I can't recall people telling stories of their recent "kill". Maybe we need a new "recent kills" forum......LOL :lol:
Nallboy
Post by Nallboy »
no no no :::wrist slap:::
Our forum does not "support" kill stories
:roll:
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
Return to “Off-Topic”
