Hey everybody, i feel pretty stupid asking this, but where is the timing advance disconnect? I wasn't sure if it was in the harness somewhere, or the diagnostic port. If someone could tell me that would be great.
Thanks-Joe
Timing Advance Disconnect?
92 MX-3 1.8L DOHC BP, 17" Konig wheels, 2.5 exuast, custom CAI, inverted style carbon fiber hood, GT-Combat body kit.
- papa roached
in teh engine bay, the diag port, jump pin 10 and a ground and set everything after teh car has reached running temp
