Tranny Issues.. again
				Sonicxtacy02
Ok i had my transmission rebuilt yet again by aamco (2nd time in 2 weeks).  I got the car back yesterday and there is a vibration during acceleration that seems to be coming from the front right side of the car.   My rear left tire was flat and i thought that was the problem but i inflated it and the problem is still there.  I'm tryin to get some ideas as to what the problem could be.  The mounts were checked 2 weeks ago so i know their not bad but could it be that they forgot to fasten the right one?  I'm also thinkin it could have something to do with axles, which i've been told were good too.  Any ideas would help.  Thanks in advance.
							Shaun Newman
				Guest
Re: Tranny Issues.. again
I would look for any welts in the tires(probably not it), and check if you have a torn boot which could in turn be a worn axle shaft.
						- MAZDASPEED STEVE
Hey Shaun could it be a wheel bearing? sounds like it
Is it getting worse?
THANX
MAZDASPEED
STEVE
						MAZDASPEED
STEVE
Vibration on acceleration can come from grounded or missaligned motor mounts. Brake tourque the engine and have someone check under the hood and watch for engine movement. be careful. Bad wheel bearings will not cause a problem on acceleration only. If you did not have the vibration before the work was done it is probably related to the work performed.
				Sonicxtacy02
Steve you were absolutely right.. it ended up being the wheel bearings.  Aamco paid for them in full. I FINALLY HAVE MY CAR BACK!!!!
Shaun Newman
- MAZDASPEED STEVE
Good to hear Shaun! I hope your MX is smooth! I remember when I replaced my wheel bearings the difference was like night and day!
Happy cruzin
							Happy cruzin
THANX
MAZDASPEED
STEVE
						MAZDASPEED
STEVE
