turbooooo?
Re: turbooooo?
street-imports.com is supposed to be coming out with a v6 turbo kit early summer...dunno if that helps your or not... ![Shrug :shrug:](./images/smilies/shrug.gif)
Re: turbooooo?
honestally, i jus want the cheapest, FASTEST way to get my car faster is all...
Re: turbooooo?
i should jus drop that 200 horse 2.5 in there... i mean why the hell not? could i turbo that too? or would that be a BIG custom job too?
Re: turbooooo?
if you stick with the 1.8 or get the klze the job is still custom for the turbo. getting the klze would be alot better as you dont have to run as much boost and your engine will run alot longer.
all in all turbo is a big undertaking .. you can get about 5-7 psi safely with turbo or supercharge on stock klze internals. Anymore your doing internals (more money). way out your options if you in the states and you want speed and got cash just buy a bloody evo they can be made 500hp on stock internals .. sick sick sick ..
the mx-3 is a total sleeper though , alot of people who have supercharged or turbo have bumped there hp up to about 350 stock .. you could get 500 out of a klze easy but internals would need to be done and a nice big turbo would help with heat issues as a small turbo will probably cause more grief than good, remember small space, especially if you have ac in there.. battery has to be moved to add intercooler unless you really want to get creative
. but hey a huge turbo would eliminate the need for huge intercooler.
If you looking for the quickest bang for the buck .. bottom line is KLZE Swap with 100 wet shot of nos. Providing you can drive it well youll be in low 12's - low 13's easy in the 1/4 mile..
- papa roached
Re: turbooooo?
and i just spent $600 on 280 degree cams, boy i wish i had known thisOriginally posted by Jon_Carnie:
street-imports.com is supposed to be coming out with a v6 turbo kit early summer...dunno if that helps your or not...![]()
Re: turbooooo?
can the ze handle a 100 shot of nitrous? that would be amasing... thats 300 hp right there...Originally posted by korban:
oh and on a side note: if u have an intercooler without forced induction its just mostly for show right? like... it doesn't actually help all that much does it? ive seen a couple of ppl's cars that have them... but no Turbo
<small>[ May 18, 2004, 11:20 AM: Message edited by: Trancelucent ]</small>
-Damian
***if u know of/have a mx-3 GS with a blown engine and live around me... let me know
- babyblueMX3
Re: turbooooo?
it's pretty pointlesss to put an intercooler without turbo since there's no hot air to be cooled...you'll only suffer from pressure drop ![Shrug :shrug:](./images/smilies/shrug.gif)
RIP 400whp ZE-T MX-3
Re: turbooooo?
there is no pressure drop when your not "turboed"Originally posted by babyblueMX3:
it's pretty pointlesss to put an intercooler without turbo since there's no hot air to be cooled...you'll only suffer from pressure drop![]()
there is no point to put an intercooler on a non turboed car
just get a coldair intake
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
2004 RX-8 - Project
Re: turbooooo?
There is, indeed, pressure drop. The pressure that fills the cylinders on the inlet stroke is atmospheric pressure. Resistance to the flow through the induction tract results in pressure drop. The intercooler presents resistance to flow.Originally posted by Marlon:
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system![Smile :)](./images/smilies/icon_smile.gif)
