SOHC turbo manifold
SOHC turbo manifold
Hey I wanna build my own manifold for my sohc with parts from this place, http://www.jgstools.com/turbo/ . The problem is that the flange they offer is for the B6 (Miata I'm guessing) and I know that it won't bolt up to my sohc. So I was wondering if the actual exhaust ports lined up or not. If so they could send me the flange with the exhaust ports cut out and all I would need to do is drill the holes to fit my head. So does anybody know? Sorry for the long post.
marshmallow15
Re: SOHC turbo manifold
eheh i remember when i first found that site, there was NO interest.. anyway you can get some 1/8" thick steel, trace the flange gasket onto it and have someone with a plasma cutter cut it out for you... and wala! instant b6e flange.
- team slideways
- team slideways
boostedmx
use your flange and go from there. its thick and steel so i dont see the problem
DRAG SPEC MX3 BEING PARTED OUT.
BUY ALL MY STUFF OR DIE.lol, SERIOUSLY BUY MY STUFF. PLEEEASE
boostedmx
cut the flange away from the header and use your flange as a starting point. take it to someone who can weld and make sure the manifold will align the turbo correctly and the downpipe also..
Ahhhh...Sorry for the stupid question.
I have to quite reading through posts during my 'down time' on Friday nights.
No Sig
Manach
Now, I can reply to that quoteOriginally posted by marshmallow15:
If you take the exhaust mani and cut the lower plate for the turbo, there might be some trouble with the turbo alignement, and the feed alignement.
My friend just tried that with his 1.8l SOHC, a bore of our 1.6l.. and encounter that trouble.
Manach
Ex Mx'er with a Mx-3 1993..
Still in the Mazda Familly with :
-Mazda Rx-7 1987 GXL (Not running, one housing does not compress)
-Mazda Protege MazdaSpeed 2003.5 Titanium!
Still got 3 Engines!
- B6-ZE : Turbo Festiva project (Waiting donor car)
- BP-DE : Trader for a B6-ZE 1994 for parts upgrade in the Festiva project
- K8 : For sell. Pm me for info!
Once you go turbo, you can never go back!
marshmallow15
can you clarify on what you mean by turbo and feed alignment? you mean mating the turbo to the stock header runners?Originally posted by Manach:
- team slideways
- team slideways
Manach
Nah, we found some place on the block to feed the turbo with oil and prestone..Originally posted by marshmallow15:
Juste an adapter.. there was a bolt there.. but if we use an adapter too long, we can't even plug the hose..
Manach
