Car runs like super crap until it gets warmed up.
Re: Car runs like super crap until it gets warmed up.
Do you have any cracks in the intake? Is the VAF connected. I don't know if it will run after it warms up without the VAF, but sounds kinda like how mine ran when I forgot to hook VAF up.
THIS USER HAS BEEN BANNED, DO NOT DEAL WITH HIM. - MX-3.com Admin
Maybe a head gasket problem that seals when it is warmed up? I'm just throwing out ideas not trying to scare you.
check you coolant temp sensor
- MX-3 Money
Hey the exact same thing just happened to me, and it was a head gasket! Sorry man, hope thats not it.
1993 MX-3 GS 5 spd, KL-ZE swap, kl31 ecu, 110 amp alternator, Unorthodox Underdrive Pulley, SSautocrome headers, High flow cat, Pacesetter high flow cat-back, B&M shortshifter, Clear Sigs/Sides.
I got the same thing with my KLZE, its the valve cover gaskets for me
93 GS, KLZE, KL31 ECU, Centerforce Stg 3 Clutch, 2.25" Exhaust w/Flowmaster muffler, OBX Headers, Pheno Spacers, Front & rear X-drilled/slotted Rotors, KVR pads, SS brake & clutch lines, Ractive Filter, H&R Springs, Tokico Blue Struts, 8mm Accel Wires, MSD 6A w/ Blaster 2 Coil, HVAC Indiglo Panel. *Sold*
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
keep me updated, i have the exact same problem - but I suspect ot to be the coolant temp sensor near the IM, because hwen I plug it in , and un-plug it , it does absolutely nothing
1992 Mazda mx3 gs / 03 / ms8 intake manifold / klze 67mm bored TB/ Custom CAI / 2.5 Custom exhaust / Drift kit front and sides/ CF Invader hood / 17'' MSR gunmetals with chrome lip / Tockico Blues / Suspension technique springs / Leather interrior/ B&M SS / Fully customized interrior (Red and black) / Corvette Red 00 Paint w/ white,blue,gold pearl / Shaved altezzas w/ black trim/ Front rear strut bars / ze ecu ( I think that's all )
Even if I was, I took my check engine light bulb out
ahahahah
MY car = no egr = check engine
Instead of the CEL, you can connect an LED between FEN and GND in the diag box, to read the codes.
<small>[ December 24, 2004, 11:45 AM: Message edited by: IanL ]</small>
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system![Smile :)](./images/smilies/icon_smile.gif)
