help me
hoffman_BMX89
help me
ok my cv boot cracked and riped apart so i got a new boot and i am goinna put it on but the big 32mm nut on the axel i cant get this p.o.s off i un crimped the piece where they phiseled it in but i still cant get it off i tried to heat it wd-40 it and nothing does anyone have any ideas
95 Mx-3 GS [R.I.P.]
96 Mx-3 GSR [Sold]
97 Mitsubishi eclipse spyder [For Sale]
97 Saturn SL2 [Sold]
03 Corvette Z06 [Current toy]
98 Saturn SL2 [Daily]
http://www.cardomain.com/ride/2176731" onclick="window.open(this.href);return false;
96 Mx-3 GSR [Sold]
- babyblueMX3
Re: help me
what are you using to tkae it off ? I used an electric 7.5A impact and took 10min to take that bolt off the first time I did it
RIP 400whp ZE-T MX-3
- bmwm3guy
Re: help me
Im pretty sure you're not supposed to use an impact gun on the 32 MM nut... I used a big pry-bar, and slid a 5 foot pipe onto the pry-bar. I basically had a 5 foot pry-bar and it took me 2 minutes.
“Give me a place to stand and a lever long enough and I will move the world”. Archimedes, 220 BC
- babyblueMX3
Re: help me
yeah I knew that but didn't have a 5ft pry bar :p
Re: help me
I cut mine off with a grinder and bought a new nut
- bmwm3guy
Re: help me
ok.. ??? how does that help? You cant change the Boot with the CV still bolted in.Originally posted by XxAntwawnxX:
i never removed the axel nut.
hoffman_BMX89
Re: help me
ok i finnaly got it off i heated it and used a pipe and it worked thats a lot for your help guys by they way i also just ended up buying a new axel because the bearings looked pretty shreaded up only cost me 140 buks with 3 quarts or gear oil too i changed that while i was at it everything is running smooth now
95 Mx-3 GS [R.I.P.]
96 Mx-3 GSR [Sold]
96 Mx-3 GSR [Sold]
