Pasesetter Short Shifter...
Tyler17rose
I ordered it today and am about to order some bronzoil shifter bushings, just to be sure before i do i want to ask if they fit? I read when searchin that someone couldnt get the bronzoil bushings to fit in with his pasesetter shifter. <p>Thanks for any help.
Mods:
- ZE, Mike seli 214 intake cams, Ported n polished heads, Interprep valve springs, DE retainers, rebuilt bottom end, toga main and rod bearings, toga hv oil pump, CZT 67mm tb, mbx udp, ported intake mani, SS headers, 2.5inch full exhaust, racingbeat muffler, highflow cat, megasquirt v2.
new toy, 86 TII rx7, JDM S5 motor/turbo, + alot of other goodies
- monstar-mx-3
Re: Pasesetter Short Shifter...
where did you order it from and how much? I havent heard good things about it.
Tyler17rose
I got it from Goldwing Auto for 100 cnd. Does anyone have any info on fitting bronzoil bushings with the Pasesetter shifter?
Mods:
- monstar-mx-3
short shifter<p>This is for a proage but its a same. This is what i got
JasonH
SRD bronzoil shifter bushings come in a set of four; two for the shifter and two for the other end of the transmission linkage (at the transmission.)<p>They do not fit the Pacesetter shifter. You can, however, use the bushings that go on the transmission side of the linkage.<p>The Pacesetter does come with new bushings. They are a harder material than stock.
Tyler17rose
Thanks! Its a good think i havnt ordered them yet then... maybe i'll still get them for the other 2 useable bushings though...
Mods:
The bushings that come with the pacesetter are CRAP. You'll end up with a shifter that has lots of left/right play. Its irritating and I haven't found a way to fix it. Otherwise the pacesetter is a good shifter.
I got the paesetter shifter and havent had one problem with it since the day I got it. Doesnt move side to side or anything.
Tyler17rose
That makes me feel alittle better
, for a minute there i thought i had made a mistake.
Mods:
- monstar-mx-3
i have heard mixed review with pacesetter. Some things they make great items...other are crap...just the luck of the draw. I bought a few things with thier name..and no problem. I in intested in the TMW short shifter. it 45% shortager.
- Custommx3
- Site Administrator
I have it as well as my friend Paul. We both seem to like it. My friend mark who has the B&M is going to get the pacesetter because its has a more adjustable throw than the B&M which cannot be adjusted.
Tyler17rose
How low did u set yours barry? I think i'm gona set it at the lowest... Oh and is install a sinch?
Mods:
- Custommx3
I set mine almost as low as it goes.. seems to shift smoother that way. (as opposed to all the way down.)
Tyler17rose
Thats what i'll do then... also are the bushings that come with it good? Or should i try to find something else?
Mods:
Installation couldnt have been any easier. You can put it as low as you want but I put mine like 3/4 of the lowest and its damn short.
