Sorry, I don't have that information, but if the resistance is infinity, it sounds good.Originally posted by Mariusz:
Correct, there is a a small box connected to the body of the distributor and on the other end trough a thin cable to the A 3pin. There is no short trough it, but also the resistance of it is inifinity. What capacity should it have ?
Dead MX-3
Re: Dead MX-3
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system
mmx01
Re: Dead MX-3
Tomorow i will put my MX-3 to the workshop, i don't have any idea whats wrong. And it still don't want to start.
Dreaming about K8 to KJ swap :]
mmx01
Re: Dead MX-3
My MX-3 is back on the wheels
Thanks to the new ignition module.
Re: Dead MX-3
Good news! Now why was it ok when it was tested in the lab - didn't they test the coil with the module?Originally posted by Mariusz:
My MX-3 is back on the wheelsThanks to the new ignition module.
mmx01
Re: Dead MX-3
Probably not. But why they told me that the ICM is OK I don't know. That was the reason of my troubles because I had information that module is OK.
