do not shave your flywheel
- babyblueMX3
I had some major problem with my car for abouth a month until 2 weeks ago when it didn't want to start anymore..It seems that my act z62-hdss clutch was putting too much pressure on my shaved flywheel so it warped and broke...thank god my clutch is still ok...
this is only for guys that want to shave their FW..don't do it..maybe with a stock clutch it's ok but with an act clutch...don't even think about it..
I had my FW shaved to 13 pounds
learn with others mistakes
<small>[ June 24, 2004, 01:03 PM: Message edited by: babyblueMX3 ]</small>
RIP 400whp ZE-T MX-3
- papa roached
Re: do not shave your flywheel
*looks at 9lb aluminum*
sorry to hear man, much sux
**** i have a centreforce and 13.6lb shave flywheel.... i guess we will see what happens
- babyblueMX3
I had the flywheel shave for 4 months of use
				bubbaflaat
Hmmmm,  lol i have a 13lbs shaved flywheel and a ACT clutch, and I haven't had any problems.  How are you so sure it is because of the lightened flywheel?  Where did you get it shaved, they might not have balanced it good enough.  Who knows, did it have any symptoms before it broke?
							THIS USER HAS BEEN BANNED, DO NOT DEAL WITH HIM. -  MX-3.com Admin
						- babyblueMX3
because my mechanic saw the flywheel and said to me I'm going to laugh when I'll see it..When he took off the tranny and clutch he saw it right away what was the problem
the symptoms were hard shifting...when I reved high I would have a hard time shifting into gears..and by the end I couldn't shift anymore.
				MazdaManiacMx3
yeah my mechanic told me not to do it he explained that the flywheel is layed so when you take off the layers that are hardened they flywheels tend to crack.
							93 Kandy Tangerine Mx3 GS-DE
02 Subaru Impreza OBS
& Lots of Toys to haul
				bubbaflaat
Well, i guess i'll have to wait and see what happens.
						- babyblueMX3
I'll take a pic for you of the flywheel when I'll get my car..
How long have you got it on your car?
did you drag with it yet?
<small>[ June 25, 2004, 02:26 PM: Message edited by: babyblueMX3 ]</small>
- babyblueMX3
there you go...sorry for bad pics
<img src="http://memimage.cardomain.com/member_im ... 08_140.jpg" alt=" - " />
see the part at the right well it's suppose to go in the middle but it broke...
				Mradio
sorry to hear about your problem, it's very strange.
i had a lightened stock flywheel with a southbend clutch for 2 years now, now problems at all.
Check out my ride and leave some feedback please!
http://www.cardomain.com/id/mradio007
Me and my friend both have Ze's and we both got Fidanza 9 pound flywheel, both fell apart where the clutch will not grab. you can drive the car but it will slip if you add to much gas.... the clutch is like 1 year old... got the flywheel from RR-racing
							2.5 KL-ZE, BBS rims, I the front i have to falkin Azenis, Intrax Springs, CM Stage 1 clutch, and Fidanza flywheel, Pacesetter short shifter, Tociko Blue Struts, Sparco Steering Wheel, Yellow Top Battery
Alpine Type R Subs 10's, Alpine 2 Channel Amp, Alpine 4 channel
Amp, Alpine Alarm,Alpine Headunit
14.8 @ 94.2(with vaccume lick)
