Just found this, so I thought I'd share it:
http://rs-productions.com/RSP_Motors/tech/research/vacumn.htm
Save to your HDD - the link may break!
GOOD KLZE Vacuum Diagram
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system![Smile :)](./images/smilies/icon_smile.gif)
- babyblueMX3
Re: GOOD KLZE Vacuum Diagram
that's a good one Ian but a repost...When I wanted too redo mine i searched and found it..
RIP 400whp ZE-T MX-3
That is the OEM diagram on a straight neck manifold. Problem is, no one here uses that manifold.
Back in November or December, I posted a thread about help with my vac hookups. Once I figured it out, I posted pics and labeled what each goes to on the curved-neck style manifold. Much easier to read & understand than those technical diagrams![Smile :)](./images/smilies/icon_smile.gif)
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Hey Gro do you think you could post a link to that thread because I am getting a curved neck MS8 mani and I know I will need help hooking up the vac lines
- babyblueMX3
hey gro...about that diagram first posted sure is for stock straight neck manifold...but it's the same anyways..just the nipple are placed someplace else..I used it to hook up my vacuum on my millenia manifold
