i saw the vid to the Uber-turbo V6 MX-3 (the 300 hp one, forget the owners name), what radiator did he use for a upgrade, im looking for a rad that would be simple to make it fit, any suggestions?
<small>[ May 23, 2004, 03:37 PM: Message edited by: papa roached ]</small>
Radiator
- papa roached
Radiator
- goldsberry1
Re: Radiator
i know there is one for the probe gt and mx-6. i'm not 100% sure if they will be a exact drop in for our cars though. they are all so around $500. i cant remember the website. it was on my other computer that my wife took off with. but they are out there, somewhere.
92' mx-3 gsr, built engine, forged internals, p/p ze heads. t3/t4e .63/.60 turbo, udp, msd ignition, millenia s injectors, millenia im, water cooled intercooler, afpr, fmu. running at 7 psi right now
Re: Radiator
best bet is to measure what available space you have and then go shopping at a wreckers yard wit your measuring tape. youll probably end up with a wicked one for cheap..
