Test Pipe ?
Test Pipe ?
Since I will be swapping the KL-03 soon, will the test pipe for the 1.8 mx-3 work? or do I need to get one for a probe?
						- Zoso124
Re: Test Pipe ?
Sure you know a test pipe is? If you planning on doing the swap your going use your K8 exhaust manifolds and you won't have to modify any of the exhaust.
							Mike Evans
Gone:
						Gone:
