I'm a bit confused here. I have read KLZEs should have KL31 cams. Then I read that some KLZEs could have KL01 cams, but is still a ZE. I read that KLDE cams are KL03. Are all of these facts correct? If so, what are the differences between the engines that have KL31 cams and KL01 cams? A little clarfication would be awesome!
<small>[ February 08, 2004, 04:22 AM: Message edited by: thebox ]</small>
KLZE cams
KLZE cams
1992 MX-3 GS
KLZE - Fidanza Flywheel - CM IIR Clutch - Millenia IM - UR Pulley - IM Spacers - KL36 ECU
- babyblueMX3
Re: KLZE cams
yes ze's came with 2 different cam profile..kl31 and kl01..the kl31 cams came with the j-spec mx6 only..it develops more hp's but less torque and is the opposite with the kl01..kl31 cams has a higher lift than kl01..that i know for sure...but i thought that probe gt's came with kl01 cams too?
RIP 400whp ZE-T MX-3
Re: KLZE cams
so the kl-de cams would make more torque than the kl-ze cams if they were in a kl-ze? and they woulmd make more torque in a kl-de than the klze cams would?
94 mx3 gs (sold)
92 Mitsubishi Eclipse GSX(14.3 @ 99.08- almost completely stock)
Re: KLZE cams
KL-01 and KL-31 are not the part numbers.
They are just ID numbers that mazda uses to show that the part will inter change with certian engines.
look at your PCV valve, it says KL-01 but its on a K8 engine, as well at the valve cover gaskets.
MOST ZE's have the KL01 cam markings on them, but they have different lift than the KL01 cams in the KL-DE.
The KL-31 marked cams have a different profile as well, but if you have a set of the kl-31's at least you know that they are from a ZE
Yes, I AM a bastard
Yes, I AM a bastard
