My car tried overheated, untill i turned my heat on, then it went down extremely quick...any ideas...i have a klze
thanks in advance
Mykil²
Overheating question.....
Re: Overheating question.....
radiator is clogged
Sacramento Raceway, CA
92 Mx3 GS
New Time 13.82 at 101.75 2.205 60ft (RIP beast klze engine)
Updated mods now... KFZE, SS Autochrome Headers and a Sweet a-- 3' Electric Cutout after it, KFZE LSD trans, Millenia manifold, KL36 ecu, Blown motor mounts, custom CAI, Custom ground wire kit, 9mm Plug wires, 2 1/4 exhaust, (Hei and MSD external coil mod), all accessories.
92 Mx3 GS
check for leaks, cooling system compression for a week or so. keep your eye on the temp guage. if it only happened once u might not have anything to worry about. strange thing happened to me too a few days after my ze went in. i spoted my temp guage going up so i blasted the heater. the guage went right back down to normal like the thermostat got stuck or something. ever since the temp guage never goes above normal, and my heater gets only lukewarm at the hottest setting when it used to cook me.
Sounds like it stuck closed the first time, then unstuck, and now its stuck partially open.
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system
