Hey all,
 Lately (as of last week) my car developed this whine on top of the engine sound. It sounds like when power steering is out and you turn the wheel Except that it's louder when it's cold, and it always whining. Sounds like a belt to me, but I know very little about such things.
 Now some background info.
 I have a coolant leak from the seal on the rad cap. (Thus, I add antifreeze/H20 every couple days)
 When I start the car, it squeals (like when you need a new fanbelt)
 The only other time it makes this squealing noise is When I've got the clutch pedal in, and I press on the gas to match revs going into third. (synchros are going)
 So yeah. Anyone know why my car sounds like it has a supercharger, then squeals like a pig when I downshift?  I have a feeling I should be visiting my mechanic soon, but I figured you guys might help me out of getting screwed by them.
 T'anks,
 Todd
  <small>[ October 02, 2003, 05:01 PM: Message edited by: Zoso124 ]</small>
							Whining sounds.. Need some opinions.
				Xero
-Only Two things are infinite, the universe, and human stupidity; and I am unsure of the former. -Albert Einstein
						- Zoso124
Re: Whining sounds.. Need some opinions.
You check the power steering fluid? Are the belts tight? Hows the coolant level now?
My guess is you just have to tighten up one of the belts.
Mike Evans
Gone:
						Gone:
				Xero
fluids are all okay. How do I check the belt tightness? Just pull on it to see if there's play?
				TsiMiata
Does the whining change with engine speed or road speed?
91 Eagle Talon Tsi AWD *RIP*
- Zoso124
Uh huh, unless you have a tool to test for deflection, but who does.Originally posted by Xero:
Mike Evans
Gone:
						Gone:
power steering pump is going
				UrBaNsTyLe55
they may sound dumb but if you belts are tight spray armoral on it or any type of spray that makes your tire shinny and if its the belt it will make the sound go away but it sounds like a power steering pump
							92 323 KF-ZE V6 swap done by me 2 1/4 header back exhaust no cat car now for sale for very cheap! email me at queensnysfinnest@aol.com for pics and questions
				potatochobit
your alternator could be going out. it will whine at high RPMs.
				lakersfan1
I'm thinking you might be spewing antifreeze on your belt and might be causing the sound???
