Cam Gears for KLZE
jdm_man
Cam Gears for KLZE
does anyone know if someone makes cam gears that will fit the KLZE engine??
TsiMiata
Re: Cam Gears for KLZE
Mazda
Because of the design of the KL series engine cam gears wont do anything for it, so in turn nobody makes them. The intake and exhaust cams are driven by one cam gear on both banks of cylinders. The gains from cam gears are being able to adjust the intake/exhaust cam timing seperately. You wouldn't be able to get that effect changing the cam gear on this V-6 engine.
91 Eagle Talon Tsi AWD *RIP*
