kl03 or klze??
kl03 or klze??
Please help me out, I've been searching a couple of hours by now and I just can't find a satisfying answer. Today a bought a 2.5 engine, It has the Millenia Intake manifold, with big square runners and the curved neck. But can I tell from this if it's an klze or just a kl03?<p>I hope someone can help me out, thanks
17 inch bba racings rims, apex lowering springs, laser muffler, boost steering wheel, mazdaspeed seats, black altezza's, testpipe, oh and a polished klze with an upgraded clutch and a kl36 ecu.
Re: kl03 or klze??
ZE with square runners, 03 with oval.<p>also check that the heads say KL31
Re: kl03 or klze??
That's the problem, it doesn't say kl31. But normally square runners only come with the ZE's?
- Custommx3
- Site Administrator
Re: kl03 or klze??
Mazda millenia, KL w/ square IM runners exactly like a ZE.
Re: kl03 or klze??
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Bastian:
That's the problem, it doesn't say kl31. But normally square runners only come with the ZE's?<hr></blockquote><p>so....what do your heads say???
Re: kl03 or klze??
My head says Kl484986
- babyblueMX3
Re: kl03 or klze??
well i beleive it's suppose to be written kl31-1O1 and kl31-1A1..to be a ZE..That's what's written on mine
RIP 400whp ZE-T MX-3
- Custommx3
Re: kl03 or klze??
If it doesnt say KL31 its not a ZE, its probably a 95+ millenia engine,
- Zoso124
Re: kl03 or klze??
Most 95+ Millenia's will have KL31 on the heads, you just have the KL01 cams and semi/dished pistons.<p>[ August 03, 2003: Message edited by: Zoso124 ]</p>
Mike Evans
Gone:
Gone:
Re: kl03 or klze??
Hiya, guys...<p>Sorry if I'm out of line, but is this the right spot to ask a couple of questions regarding an engine swap?<p>If so, and I want to go from my 1.8 to a Mazda 2.5, what year provides the easiest swap, and is the better engine year?<p>Thank you for your tolerance...
Denny
Denny
- Custommx3
Re: kl03 or klze??
all V6's w/ 5 speed. They are all the same as far as engine goes.
Re: kl03 or klze??
To Zoso, so you are saying the only difference whith the klze will be different pistons? So if I change the pistons and ecu I will be able to get the 198 hp? How much hp can I pull out of the Millenia Engine?
Re: kl03 or klze??
cams are also different.<p>[ August 05, 2003: Message edited by: Darren Hyderman ]</p>
Re: kl03 or klze??
So you're saying there's no easy way to get the klze power out of a Millenia engine? That sucks!
- Custommx3
Re: kl03 or klze??
yes u can.. change the pistons, put in some interprep cams, you should have more power than a ZE. w/ motor, pistones, and cams +install, your looking @ more than the price of a ZE.
