cd player dosent work
well i hooked up my cd player and it work fine and sound was good, and then i cranked up my volume almost like 40 then it turmed off because i think i push my max watts so i turn the car off and my cd player goes on but theres no sound
Re: cd player dosent work
Check the wiring harness. The vibrations could have knocked a wire loose.
everything is good and snug together
Fried internal amp on the CD player?
93 GS, KLZE, KL31 ECU, Centerforce Stg 3 Clutch, 2.25" Exhaust w/Flowmaster muffler, OBX Headers, Pheno Spacers, Front & rear X-drilled/slotted Rotors, KVR pads, SS brake & clutch lines, Ractive Filter, H&R Springs, Tokico Blue Struts, 8mm Accel Wires, MSD 6A w/ Blaster 2 Coil, HVAC Indiglo Panel. *Sold*
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
Does the radio still work? is it just the CD gone? or both.
- Typhoonk
Cool...... Anyway, first thing I would do is unplug all the plugs from the rear of the deck and let it cool down for a bit. Then plug it in and see what it's doing.
#2. Check your speakers with a walkman to see if they work.
#3. Try each speaker out one by one on the back of the deck.(couldn't have just fried one speaker, or one output)
#4. Go spend some money on an amp and run off of the pre-outs.
<small>[ June 12, 2004, 01:53 AM: Message edited by: Typhoonk ]</small>
PM for info
PM for info
BumpNGlow
you've checked fuses on the HU right?
FOR SALE, AS A PARTS CAR
1994 Mazda MX-3 <-- 152dB's w/ 1 15
> Invited to '02 USACi World Finals, but did not compete due to stock alternator problems.
> Can't go to '03 USACi World Finals because I HAVE NOTHING LEFT!!
yup all of the fuses are ok and i took every wire off from the back of the cd player when i hooked up the acc, 12v and ground and connected a speaker from the back, the CD player when on but there wasent any sound coming out, i tried every wire to.
