question about tranny's
ive always wondered while in reverse when you start to move it whines, you all know what i mean, and even new cars with manual trannys do the same thing, just wondering what it is! ![2 Thumbs Up :2thumbsup:](./images/smilies/2thumbsup.gif)
sold the mx-3 , bought 04 gtp comp g , from the smallest v6 to one of the biggest 3800 s/c FTW
- papa roached
Re: question about tranny's
i think its from the fact that reverse is geared so low the internals are spinning pretty fast
first is geared fairly low as well tho so wouldnt that whine as well? im sorta talkin outta my azz but im jw
- Typhoonk
try getting first up to 5000rpm and let it coast - it will whine pretty good!!
PM for info
PM for info
You know, i've always wondered that, i've just never posted it...i cant see it being teh gearing, honnestly, it wouldnt surprise me if reverse was actually longer than our first gear
you hear the whining sound because normal driving gears such as first, second and third are angle cut gears like your cam gears, so they spread the area of force across a larger area for more torque and higher speed, while reverse gears are straight cut gears because they dont need to be used for high speed purposes or large amounts of torque.
You know the world is going crazy when the best rapper is a White guy, the best golfer is a black guy, The Swiss hold the America's Cup, France is accusing the US of arrogance, and Germany doesn't want to go to war
